SNAP-TEX-CBE6
SNAP-TEX-CBE6
$160.00 (USA and Canada only)
8-wire Cable for SNAP I/O Modules, Even Terminals Connected
Part of the SNAP TEX family of mounting and wiring accessories, the SNAP-TEX-CBE6 cable provides neat, protected wiring from the top of a SNAP I/O module to a SNAP TEX breakout board. The cable is six feet (1.8 m) long.
Installation, maintenance, and troubleshooting are faster and simpler using SNAP TEX cables. Each cable snaps into the top of one module and terminates at the breakout board with 18-gauge, color-coded flying leads, already stripped and ready for wiring. The leads attach easily to the breakout board with spring connectors.
NOTE: On the SNAP-TEX-CBE6, even-numbered terminals are connected. Do NOT use the CBE6 with a SNAP-TEX-FB16-H or -L breakout board, since the FB16s have odd-numbered pins connected.
This cable can be used with many digital input modules, some digital outputs, and some analog inputs and outputs. See the data sheet for details.
Or see: Modules, Cables, and Breakout Boards Compatibility Charts
Feature
SNAP-TEX-CBO6
SNAP-TEX-CBE6
SNAP-TEX-CBS6
Cable length
6 feet (1.8 meters)
6 feet (1.8 meters)
6 feet (1.8 meters)
Connector
8 pins, 0.2 in. (5.08 mm) center-to-center
Wires
8 pre-stripped, color-coded, 18 gauge
Bussing
Odd-numbered pins connected
Even-numbered pins connected*
No connected
CE, RoHS, DFARS
CE, RoHS, DFARS
CE, RoHS, DFARS
30 months
30 months
30 months
*Do NOT USE the CBE6 with a SNAP-TEX-FB16-H or -L breakout board. The FB16s have odd-numbered pins connected.
SNAP TEX Cables and Breakout Boards Data Sheet
SNAP TEX cables and breakout boards are part of the SNAP TEX family of wiring and mounting accessories. These parts save time and expense during installation, maintenance, and debugging by reducing the time and effort required to wire field devices to SNAP I/O modules. This data sheet covers the following part numbers:
SNAP TEX Cables Installation Note
SNAP TEX cables make wiring to field devices easier. This installation note shows how to install the following cables:
Video: Spring Clamps - Quick Tip
A quick tip on spring clamps.
Video: SNAP TEX Wiring and Mounting Accessories
A quick overview of SNAP TEX wiring and mounting accessories.
