SNAP-IAC5MA
SNAP-IAC5MA
$158.00 (USA and Canada only)
SNAP 4-Ch Isolated 90-140 VAC/VDC Digital (Discrete) Input Module with Manual/Auto Switches
The SNAP-IAC5MA provides four channels of 90-140 VAC/VDC digital input. Each channel senses the on/off status for AC (or DC) voltages from sources such as proximity switches, push buttons, or auxiliary contacts. This module features manual-on/manual-off/automatic switches that override input from field devices and are ideal for testing control applications.
SNAP-IAC5
SNAP-IAC5A
SNAP-IAC5MA
Key Feature
Diagnostic switches
Wire size
22 to 14 AWG
22 to 14 AWG
22 to 14 AWG
Torque, hold-down screws
Torque, connector screws
5.22 in-lb (0.59 N-m)
Nominal Input Voltage
120 VAC/VDC
240 VAC/VDC
120 VAC/VDC
Channel-to-channel isolation
300 VAC
(1,500 V transient)
300 VAC
(1,500 V transient)
300 VAC
(1,500 V transient)
Input Voltage Range
90–140 VAC/VDC
180–280 VAC/VDC
90–140 VAC/VDC
Turn-on Voltage
90 VAC/VDC
180 VAC/VDC
90 VAC/VDC
Turn-off Voltage
35 VAC/VDC
35 VAC/VDC
35 VAC/VDC
Input Resistance
169 K ohms (nominal)
305 K ohms (nominal)
Logic Side Ratings
Logic Output Voltage
<.5 V max. (on)
@ 2 mA sinking
2.7 V min. (off)
@ 400 mA sourcing
<.5 V max. (on)
@ 2 mA sinking
2.7 V min. (off)
@ 400 mA sourcing
<.5 V max. (on)
@ 2 mA sinking
2.7 V min. (off)
@ 400 mA sourcing
Logic Supply Voltage*
5 VDC ± 0.25 VDC
5 VDC ± 0.25 VDC
5 VDC ± 0.25 VDC
Logic Supply Current
50 mA maximum
50 mA maximum
50 mA maximum
Negative True Logic
Output Drive
TTL 74 Series = 1 UL
TTL 74LS Series = 5 UL
Module Ratings
Number of Channels Per Mod­ule
4
4
4
Turn-on Time
30 msec
30 msec
30 msec
Turn-off Time
30 msec
30 msec
30 msec
Optical Isolation, Field to Logic
4,000 volts (transient)
Temperature
-20 °C to 70 °C, operating
-40 °C to 85 °C, storage
UL, CE, CSA, RoHS, DFARS; UKCA
UL, CE, RoHS, DFARS
Lifetime
Lifetime
30 months
* When used with an I/O processor (brain or on-the-rack controller), the processor requires 5.0 to 5.2 VDC.
SNAP PAC System Product Guide
SNAP Digital Input Modules Data Sheet
SNAP digital input modules are designed to work with SNAP PAC racks and can sense either AC or DC signals.
All SNAP digital input modules are compatible with SNAP PAC brains and R-series controllers, including Wired+Wireless models.
Most digital input modules are also compatible with SNAP D-series or legacy M-series and B-series racks and with the brains that mount on them.
This data sheet applies to:
Video: Securing SNAP Module
Video: Removing a SNAP Module
Accuracy vs Resolution
