SNAP-AIMV2-4
SNAP-AIMV2-4
$369.00 (USA and Canada only)
OBSOLETE SNAP 4-Ch -50 to +50 mV Analog Input Module
The SNAP-AIMV2-4 provides four channels of analog-to-digital conversion. Each channel can be configured for -50 mV DC to +50 mV DC or -25 mV DC to +25 mV DC. Although the four channels are not isolated from each other, the module is transformer isolated and optically isolated from other modules and devices.
Compatibility: This module can be used with SNAP PAC brains and R-series controllers. It can also be used with legacy Ethernet-based brains.
Input Range
From -50 mV to +50 mV
From -25 mV to +25m V
Over-Range Limits
From -55 to +55 mV
(+/-50 mV range)
From -27.5 to +27.5 mV
(+/-25 mV range)
Resolution
2 microvolts (-50 mV to +50 mV)
1 microvolt (-25 mV to +25 m V)
Input Filtering
-3 dB @ 2.4Hz
Input Response Time
(% of span/delta V/delta time)
63.2%/31.5 mV/66 ms
Data Freshness (Max)
335 ms (+/- 50 mV)
668 ms (+/- 25 mV)
DC Common Mode Rejection
>-120 dB
AC Common Mode Rejection
>-120 dB @ 60 Hz
Maximum Survivable Input
±15 volts
Maximum Operating Com­mon Mode Voltage
250 V
Accuracy at Full Scale
0.1% (50 microvolts) @ 50m V
0.2% (50 microvolts) @ 25 mV
Drift: Gain Temperature Coef­ficient
3 microvolts / °C
Drift: Offset Temperature Coefficient
2 microvolts / °C
Isolation
1500 V
Power Requirements
5 VDC (±0.15 ) @ 170 mA
Input Resistance - Single Ended
100 Megohms (each channel)
Operating Temperature
-20 °C to 70 °C
Humidity
5-95%, non-condensing
Storage Temperature
-40 °C to 85 °C
Wire size
22 to 14 AWG
Torque, hold-down screws
Torque, connector screws
5.22 in-lb (0.59 N-m)
UL, CE, RoHS, DFARS; UKCA
Lifetime
SNAP PAC System Product Guide
SNAP Analog Input Modules Data Sheet
SNAP I/O analog input modules are part of Opto 22's SNAP PAC System. This document includes descriptions, specifications, and wiring and dimensional diagrams for the following analog input modules:
For analog modules with channel-to-channel isolation, see Form 1182, the SNAP Isolated Analog Input Modules Data Sheet.
CAD Drawing: SNAP I/O Module
Video: Securing SNAP Module
Video: Removing a SNAP Module
