SNAP TEX Cables & Breakout Boards Compatibility
Field wiring to SNAP I/O modules is faster and easier using SNAP TEX cables and breakout boards.
These charts show which part numbers can be used together. View this information as a pdf.
Also see form 1756, the SNAP TEX Cables and Breakout Boards Data Sheet.
Charts on this page:
Digital Input Modules - 4-channel
Find your module in the left column. Choose the breakout board from the right columns. Compatible cables are shown in the table cells in the center.
NOTE: The following breakout boards are not used for digital inputs: SNAP-TEX-MR10-4, SNAP-TEX-MR10-16,
SNAP-TEX-MR10-16C
Digital Output Modules - 4-channel
SNAP-TEX-FB16 boards (first column) are preferred for digital outputs because they include fuses.The SNAP-TEX-32 (second column) can be used with digital outputs, but it has no fuses.
High-Density Digital Modules
Analog Input Modules - 1-, 2-, and 4-channel
Do not use thermocouples with breakout boards.
The SNAP-AIPM-3 is not recommended for use with breakout boards due to CT safety concerns.
Module |
Compatible Breakout Board |
Used with this Cable |
SNAP-AIARMS
SNAP-AIARMS-i
SNAP-AIARMS-i-FM
SNAP-AICTD
SNAP-AICTD-4
SNAP-AILC*
SNAP-AILC-2*
SNAP-AIMA-i
SNAP-AIMA-iSRC*
SNAP-AIMA-iSRC-FM*
SNAP-AIMA-iH
SNAP-AIMA2-i
SNAP-AIRATE
SNAP-AIRATE-HFi
SNAP-AIRTD
SNAP-AIRTD-10
SNAP-AIRTD-1K
SNAP-AIV-72
SNAP-AIV-i
SNAP-AIV2-i
SNAP-AIVRMS
SNAP-AIVRMS-i
SNAP-AIVRMS-i-FM |
SNAP-TEX-32 |
SNAP-TEX-CBS6 |
SNAP-AIMA
SNAP-AIMA-4
SNAP-AIMV2-4
SNAP-AIMV-4
SNAP-AIR40K-4
SNAP-AIV
SNAP-AIV-4 |
SNAP-TEX-32 |
SNAP-TEX-CBE6
SNAP-TEX-CBS6 |
* Note that the SNAP-TEX-SBS6 cable does not include a connector for the 2-pin terminal on top of these modules, required for excitation voltage. |
Analog Output Modules - 1-, 2-, and 4-channel
Analog Modules - More than 4 channels
