SNAP-PAC-S1-FM
SNAP-PAC-S1-FM
OBSOLETE SNAP PAC S-series Programmable Automation Controller for Ethernet Networks - REST API
*** NOTE: This part is OBSOLETE and no longer available.  Use the SNAP-PAC-S1 instead. ***
Now developer and IoT ready with a built-in HTTP/HTTPS server and RESTful API.
See Programming, below.
** Compatible with groov EPIC. You can control groov EPIC I/O units with a SNAP PAC S-series controller running PAC Control R10.a or higher. **
The SNAP-PAC-S1-FM programmable automation controller provides powerful, real-time control and communications to meet your industrial control, monitoring, and data acquisition needs.
One of the four components of the SNAP PAC System, the SNAP-PAC-S1-FM is fully integrated with PAC Project software, SNAP PAC I/O processors, and SNAP I/O modules to form a complete control system. The SNAP PAC System includes digital and analog control, serial string handling, PID loops, and enterprise connectivity.
Programming
The SNAP-PAC-S1-FM is programmed using the included PAC Control software. PAC Control is a flowchart-based tool for developing control applications, or strategies. You create and debug the strategy on your computer and then download it to the PAC, where it runs independently.
REST API: All I/O point and strategy variable data is available for secure access using the built-in HTTPS server and RESTful API, with data delivered in JSON format. For complete API documentation and steps for getting started, see developer.opto22.com. In addition, two Node-RED nodes are available. Note that minimum firmware R9.5a and PAC Project R9.5a are required to use the REST API.
You can build full-featured operator interfaces (HMIs) using the included PAC Display software, which taps the same tagname database you've already developed in PAC Control. SNAP PAC S-series controllers are also compatible with Opto 22's groov products and groov View HMI tool.​
Networking
The controller is compact and industrially hardened. It includes two independent Ethernet network interfaces with separate IP addresses, which can be used to segment the control network from the company network or for redundant Ethernet network links.
The SNAP-PAC-S1-FM also has three serial ports: an RS-232 port with full hardware handshaking, ideal for PPP communication using a modem; another RS-232 port for connecting directly to serial devices; and an RS-485 port for connecting to SNAP PAC Serial brains or to legacy mistic I/O units. (Note: If you are using the S1 with misticI/O units, use the legacy versions of the PAC Control, PAC Display, and PAC Manager guides.)
For more details, see the Specifications tab and the Data Sheet.
To compare controller features, see the SNAP PAC Controller and Brain Comparison Chart.
Processor
266 MHz 32-bit ColdFire® 5475 with integrated floating-point unit (FPU)
Memory
SNAP-PAC-S1 and SNAP-PAC-S2
  Total RAM: 32 MB
  Total RAM for PAC Control Strategies: 16 MB
  Battery-backed RAM: 8 MB
  RAM File Storage: 2.5 MB
  Flash File Storage: 4 MB
Removable storage
(Models with manufacture dates of June 2014 and newer. Requires firmware R9.4a or higher and loader R6.1a or higher) MicroSD card slot: supports microSD or microSDHC cards to 32 GB.
(Models with manufacture dates of November 2008 through May 2014 with firmware R8.4 or higher) McroSD card slot: supports microSD cards up to 2 GB.
Backup battery
SNAP-PAC-S1s with serial number 625654 or higher and all SNAP-PAC-S2s: Rechargeable (recharges whenever the brain has power), 1-year power-off data retention (replacement part number: SNAP-PAC-BATTERY-ML2430).
SNAP-PAC-S1s with serial number 625653 or lower: User-replaceable 3.6-volt TL 5242 /W lithium, 10-year minimum power-off data retention (replacement part number: G4BATT32)
Ethernet Communication to host and I/O
Two independent 10/100 Mbps Ethernet network interfaces (RJ-45 connec­tors). Each interface has a separate IP address (separate subnet). Supports Auto MDI-X (crossover cable not needed).
Serial Communication
RS-232 serial: Two RS-232 serial ports (one DB-9 and one pluggable connector); one port has full handshaking. PPP is supported only on port 0. Buffer size: 512 bytes each for RX and TX.
RS-485 serial: One RS-485 serial port (pluggable connector); two-wire RS-485; optional mistic signal interrupts. Range (serial multidrop): 32 stations maximum on a segment (including PC, controller, and I/O units); up to 3000 ft (914 m) on a segment. Buffer size: 512 bytes each for RX and TX.
Four serial ports that can be used as general purpose ports or for serial I/O units; each port is software configurable as either RS-232 (Tx, Rx, COM, DTR, DCD, RTS, CTS) or as RS-485 (2-wire, 4-wire, optional termination, optional biasing); optional mistic signal interrupts. Buffer size: 512 bytes each for RX and TX.
Power requirements
8–32 VDC ±0.5, 11.3 VA maximum
(SNAP-PAC-S1 controllers with serial numbers below 500,000 use 8–24 VDC)
Operating temperature
Storage temperature
Humidity
-20 °C to 60 °C
-40 °C to 85 °C
0% to 95% relative humidity, non-condensing
Software
 PAC Project Basic
 PAC Project Professional
 REST API
Includes programming, HMI software, and configuration software; included with purchase of controller.
PAC Project Basic plus OPC 2.0-compliant OPC server, OptoControl strategy and OptoDisplay project importing, support for serial mistic I/O units, and Ethernet link redundancy support.
Use HTTPS to access data (read/write or read-only) from controller tags using your chosen programming language. Data returned in JSON. More information at developer.opto22.com
Number of charts that can run simultaneously
32
Other features
Multiple protocol support including TCP/IP, FTP, SNMP v2.0c (with firmware 8.2a), Modbus/TCP, EtherNet/IP™, and OptoMMP™.
Real-time clock
FTP server/client with file system (in RAM and in removable storage)
Ethernet link redundancy or network segmenting
Agency certifications
CE, RoHS, DFARS; UKCA
Using Modbus Devices with Opto 22 Products Technical Note
This technical note introduces the Modbus protocol and gives you basic information for using it to communicate between Opto 22 products and other devices. Because Modbus/TCP and Modbus serial are handled differently by various manufacturers, the tech note describes specific areas that may be a concern and includes troubleshooting suggestions.
This README file lists revision changes made to the firmware used in SNAP PAC S-series, R-series, and SoftPAC controllers; SNAP PAC EB-series and SB-series brains; and G4EB2 and G4D32EB2 brains.
PAC Project Readme Notes
Latest Readme for PAC Project Basic and Professional. Includes information on new features, enhancements, and bug fixes for each PAC Project application: PAC Control, PAC Display, OptoOPCServer, PAC Manager, and Tools.
SNAP Legacy Firmware README
This README file lists revision changes made to the firmware used in SNAP PAC family controllers before Version 8.0a, the SNAP-LCE controller, and SNAP Ultimate, Ethernet, and Simple brains.
Guide to Networking SNAP PAC Products
Networking can be a complex subject. This guide tries to reduce the complexity by providing guidelines for how you might set up communications between your computer or mobile device and your SNAP PAC control system.
The goal is for you to be able to monitor and control your system from anywhere you need to, either inside your facility or outside it. It's possible to do this because Opto 22 control systems are built on standard protocols such as TCP and UDP over IP, which are the same protocols used by off-the-shelf computers, routers, and the internet.
This guide shows you how to communicate with Opto 22’s SNAP PAC controllers using wired Ethernet networks and wireless LANs, both within your facility and over the internet.
EtherNet/IP for SNAP PAC Protocol Guide
This guide provides detailed descriptions of the EtherNet/IP commands that can be accessed when using remote Opto 22 I/O with an Allen-Bradley controller.
Using IEEE Floats in Opto 22 Products
While computers, CPUs, and electronic devices store numbers in binary format, most often they represent real numbers as floating point numbers, or floats. For example, in industrial automation applications, all analog values read from an I/O unit are floats.
This document describes how the IEEE 754 standard for floats is used in Opto 22 products, including groov RIO, groov EPIC, and SNAP PAC systems.
Configuring Email Applications for Opto 22 Products
You can use many Opto 22 products to send email notifications to keep engineers and technicians aware of
important conditions in your system. For example:
  • You can send email through a PAC Control strategy running on a groov EPIC or SNAP PAC controller.
  • Your groov View HMI can send event notifications via email.
  • Your Node-RED flow on groov RIO or groov EPIC can send email.
IMPORTANT: Due to security changes, you will stop receiving emails from your Opto 22 devices unless you
configure your email account with a new application-specific password. This technical note gives you details and steps to configure your account.
Case Study: Amalgamated Research, LLC
As the research and development department of Amalgamated Sugar in the 1970s, ARi began with a mission to develop efficient processes to extract sugar from sugar beets.
But over time, their continuous research in the industrial separation field has led them far beyond sugar.
Opto 22 announces strategic partnership with IBM and acceptance into the IBM Watson IoT partner ecosystem
Opto 22 announces strategic partnership with IBM and acceptance into the IBM Watson IoT partner ecosystem, providing developers a full stack end-to-end toolset for rapidly developing and deploying industrial IoT applications.
This partnershiip will bridge the gap between existing industrial assets and infrastructure, and the digital world of mobile, cloud, and information technology.
Watch this video and see how to get started.
Connect Real-world Data to an AT&T M2X Device Technical Note
This technical note shows you how to send real-world data, in this example a temperature in degrees F, to an AT&T M2X device in the cloud.
Connect Industrial Devices to IBM Watson IoT Technical Note
If you've heard about our Opto 22 SNAP PACs with their built-in RESTful API (application program interface), you may be wondering how you'd use that API to send real-world data to the IBM® Watson IoT® platform.
This technical note shows you how, step by step. This technical note is also a blog post on our website.
For more information, see Press Release 2217.
Case Study: Toyo Tanso USA
Toyo Tanso USA manufactures a fine grade of graphite called isotropic graphite, and the company also provides graphite-related silicon carbide surface treatments to customers.
The batch automation process systems used to perform these surface treatments are in a busy, tough industrial setting. The multiple vessels involved in the process each require different specializations and careful management.
To control the vessels, Toyo Tanso needed a rugged control system with plenty of I/O options—and one that could be easily programmed and deployed.
Opto 22 Conecta Digitalmente el IIoT con el Lanzamiento de Nodos de Node-RED para los PAC Industriales
PARA PUBLICACIÓN INMEDIATA: Opto 22 Conecta Digitalmente el IIoT con el Lanzamiento de Nodos de Node-RED para los PAC Industriales
Opto 22 Digitally Wires the IIoT with Release of Node-RED Nodes for Industrial PACs
Opto 22 Digitally Wires the IIoT with Release of Node-RED Nodes for Industrial PACs.
Opto 22 announces immediate availability of Node-RED nodes for its industrial programmable automation controllers (PACs), significantly decreasing Industrial Internet of Things (IIoT) application development time and complexity.
Opto 22 Permite Desarrollo Rápido de Aplicaciones Industriales para la Internet de las Cosas con el Lanzamiento de la API REST para Controladores Programables de Automatización (PACs) In
PARA PUBLICACIÓN INMEDIATA: Opto 22 Permite Desarrollo Rápido de Aplicaciones Industriales para la Internet de las Cosas con el Lanzamiento de la API REST para Controladores Programables de Automatización (PACs) In
Opto 22 Enables Rapid Industrial Internet of Things Application Development With Release of RESTful API to Industrial Programmable Automation Controllers (PACs)
Press release announcing new built-in HTTP/HTTPS server and RESTful API in Opto 22 SNAP PAC standalone and rack-mounted programmable automation controllers.
For complete API documentation and steps to get started, visit developer.opto22.com.
La API de SNAP PAC REST y la Internet de las Cosas para los Profesionales del OT
La API de SNAP PAC REST y la Internet de las Cosas para los Profesionales del OT, SNAP PAC REST API OT Technical Note (Spanish)
SNAP PAC REST API and the Internet of Things - for OT Professionals
We’ve all heard about the Internet of Things (IoT) and its promises: bringing useful data directly to people who make business decisions, and enabling machines to communicate with each other and make decisions for human benefit.
But how does the IoT actually work? How does the data get from inside these physical "things" to computer networks where it can be used?
This technical paper describes that pathway for OT (operational technology) professionals—automation professionals. It describes the kinds of data you may be asked to provide and why. It explains how data from physical "things"—especially existing sensors and actuators that have no IoT capabilities built in—can be securely communicated to company computer networks, without disturbing control networks.
The paper also explains concepts important to any IoT strategy, like encryption and authentication, and introduces a new method to achieve the IoT results you need now, without requiring a complex chain of conversion hardware and software.
Learn about the REST API and the IoT from an information technology (IT) professional's standpoint in the companion tech note, SNAP PAC REST API and the Internet of Things - for IT Professionals.
La API de SNAP PAC REST y la Internet de las Cosas para los Profesionales de IT
La API de SNAP PAC REST y la Internet de las Cosas para los Profesionales de IT - SNAP PAC REST API IT Technical Note (Spanish)
But how does the IoT actually work? How does the data get from inside these machines to computer networks where we can use it?
This technical paper describes that pathway for IT (information technology) professionals, explaining how physical "things" communicate, what kinds of data in them might be useful, and the current barriers to getting that data—especially from existing sensors and devices that have no IoT capabilities built in.
The paper also describes a new method to cut through those barriers and achieve the IoT results you want now.
Learn about the REST API and the IoT from an automation professional's standpoint in the companion tech note, SNAP PAC REST API and the Internet of Things - for OT Professionals.
Tutorial de Computacion en el Borde
2184S Tutorial de Computacion en el Borde (Spanish Edge Computing Primer - Spanish)
Su Tutorial de la IoT: Reduciendo la brecha entre OT y IT
Your IoT Primer: Bridge the Gap between OT and IT
You've probably heard about the Internet of Things (IoT). But what is it, and how will it affect our businesses?
This primer helps you understand the IoT and the significant challenges we face to realize its benefits.
The primer defines operational technology (OT) and information technology (IT), and shows how they are converging and why. It defines IoT technologies and suggests 3 steps you can take to develop an effective and profitable IoT strategy.
Opto 22 Integrates Custom Applications with SNAP PAC Control Systems
Press release: Opto 22 Integrates Custom Applications with SNAP PAC Control Systems with Opto 22 .NET Controller Software Development Kit (SDK) for SNAP PAC.
Using microSD with Older Controller Firmware Technical Note
SNAP PAC controllers manufactured in November 2008 and later have a microSD card slot in the top of the controller’s case.
Behavior for the microSD card has changed since the first release. This technical note describes behavior with controller firmware versions older than 9.0.
If you are running controller firmware 9.0 or newer, use instructions in the controller user’s guide; do not use this technical note.
Quick Guide: Troubleshooting Info from SNAP PAC Systems
This technical note provides a quick guide about diagnostic files to collect and send in to Opto 22 Product Support for analysis when troubleshooting a SNAP PAC System.
Communication Tools & Protocols for Opto 22 Products Technical Note
This technical note describes the networking tools and protocols that are compatible with Opto 22 products for communication with a wide variety of software and systems.
Case Study: Hong Kong Power Plant (Chinese)
The Lamma Power Station in Hong Kong is using Opto 22 SNAP PAC standalone controllers to control heat, pressurization and other critical processes. The Opto 22 PACs connect to weigh scales, conveyors, pressure transducers, and thermocouples to ensure that the coal burning operations taking place at Lamma are executed safely and optimally.
For example, analog I/O modules wired to scales measure the weight of the coal prior to its delivery to the furnaces and sends these figures to the controller. Based on these readings—and whether they're low or high—the controller then instructs the conveyors delivering the coal to the furnaces to speed up or slow down appropriately, so the furnaces generate the proper amount of heat needed to spin turbines that produce the power.
At the same time, integrated circuit temperature derivative probes (ICTDs) connected to thermocouple analog input modules monitor the actual furnace temperatures, which are then used in PID calculations to regulate the temperature via analog output modules.
Updating the Loader on a SNAP Device
It is rarely necessary to update the loader in a SNAP PAC controller or brain, but if you need to, this document shows you how. If you have questions, contact Opto 22 Product Support.
EtherNet/IP Implementation in SNAP PAC Products
This technical note summarizes EtherNet/IP technology and how SNAP PAC devices can be integrated into an EtherNet/IP environment to send data to EtherNet/IP enabled devices such as Allen-Bradley PLCs.
Software for Programmable Automation Controllers (Chinese)
This white paper explores some important features of programming software for a programmable automation controller (PAC).
For additional white papers on PACs, see About PACs.
Considerations for Choosing a Programmable Automation Controller (PAC)
This white paper compares programmable automation controllers (PACs) with other automation technologies and suggests several considerations to keep in mind when choosing PACs for your industrial control or monitoring application.
Case Study: Ballarat Health Services
Ballarat Health Services in Victoria, Australia, is a major health care organization comprising two hospitals, convalescent homes, psychiatric services, six nursing home hostels, and rehabilitation centers. Ballarat upgraded from older Opto 22 M4 controllers and now uses Opto 22's SNAP PAC System for equipment automation and building management. Their broad set of applications includes remote monitoring, alarming, process and discrete control, and data acquisition for performance optimization, energy management, and regulatory compliance reporting.
6 Razones Para Considerar el Sistema SNAP PAC
Este documento corto sugiere seis razones porqué debe de considerar el Sistema SNAP PAC para su siguiente proyecto de automatización.
6 Reasons to Consider the SNAP PAC System for Your Next Project
This short document suggests six reasons why you should consider the SNAP PAC System for your next automation project.
Caso: Henkel Capital México (Spanish)
Caso sobre la automización de una empresa de adhesivos en la ciudad de Salamanca, Guanajuato, México. (Case study of how an adhesives manufacturer in Salamanca, Guanajuato, México, was automated.)
SNAP PAC Memory Usage Technical Note
This technical note shows how SNAP PAC memory, both volatile and non-volatile, is used. It compares memory available in the standalone SNAP PAC S-series, on-the-rack SNAP PAC R-series, and software-based SoftPAC controllers, and it also shows differences between wired Ethernet PACs and Wired+Wireless™ PACs.
Understanding Programmable Automation Controllers (PACs) in Industrial Automation (Chinese)
NOTE: This document is written in Chinese.
This white paper describes the advent of the programmable automation controller (PAC) and its use in modern industrial applications.
For additional white papers on PACs, see the Guide to PACs.
Firmware for all SNAP PAC products (single download).
See the README document for information on changes and fixes in the current version of this product's firmware.
Selecting the Correct Version of PAC Manager to Install Firmware
To install firmware, use the most recent release of PAC Manager (you can download the latest version from the Opto 22 website). Older versions of PAC Manager cannot install certain levels of firmware on controllers and brains shipped after certain dates or with certain versions of firmware currently installed on them. The following sections explain which versions of PAC Manager can install which versions of firmware for the indicated hardware.
SNAP PAC R-series Controllers
Some SNAP-PAC-R1 controllers shipped after August 26, 2024 require firmware R10.5g (or higher) and new bootloader firmware. For instructions on identifying these controllers, review the README document.
SNAP R-series controllers shipped after February 22, 2022 shipped with new Ethernet components, PAC firmware R10.4d (or higher), and new bootloader firmware. For more information about minimum firmware requirements and installation requirements, review the README document.
SNAP R-series controllers shipped after April 2, 2018 shipped with new flash components, PAC firmware R9.5g (or higher), and new bootloader firmware. Lower versions of firmware are not compatible with these controllers. For instructions on recovering controllers that are accidentally installed with lower versions of firmware, review the README document.
SNAP PAC S-series Controllers
SNAP S-series controllers shipped after February 22, 2022 shipped with new Ethernet components, PAC firmware R10.4d (or higher), and new bootloader firmware. For more information about minimum firmware requirements and installation requirements, review the README document.
SNAP S-series controllers shipped after April 2, 2018 shipped with new flash components, PAC firmware R9.5g (or higher), and new bootloader firmware. Lower versions of firmware are not compatible with these controllers. For instructions on recovering controllers that are accidentally installed with lower versions of firmware, review the README document.
SNAP PAC Ethernet and Serial Brains
Some EB and SB brains shipped after April 2, 2018 shipped with new flash components, PAC firmware R9.5g (or higher), and new bootloader firmware. Lower versions of firmware are not compatible with these controllers. For instructions on recovering controllers that are accidentally installed with lower versions of firmware, review the README document.
SoftPAC
For SoftPAC firmware version R9.4c (or lower): To upgrade to firmware version R9.5a (or higher), you must install SoftPAC from the PAC Project installation file to update SoftPAC Monitor, then you can update the firmware. For instructions, see KB86020.
SNAP PAC S-Series Controller Bootloader
This download contains special firmware for the SNAP PAC S-Series controllers that upgrades the controller bootloader (or "loader").
Beginning with R6.1b, the loader upgrades newer SNAP PAC controllers to allow the use of high-capacity (up to 32 GB) microSDHC cards. SNAP PAC R9.4a (or higher) firmware must also be installed with the R6.1b (or higher) loader to obtain microSDHC card support.
SNAP-PAC-S1 Controller Firmware
This download contains current firmware for the SNAP-PAC-S1 and SNAP-PAC-S1-FM controllers. Current firmware for all SNAP PAC brains and controllers is available in a single download here.
CAD Drawing: SNAP-PAC-S1 Standalone Industrial Controller
This CAD file includes drawings of the SNAP-PAC-S1 programmable automation controller, a standalone industrial controller.
Controller Time Synchronization Application
This software application updates the internal clock for an Ethernet-connected Opto 22 controller. The application runs in Windows at the command prompt, and can update controller clocks regularly or just once.
This application is used with the following Opto 22 controllers:
  • SNAP PAC S- and R-Series
  • Ultimate I/O (UIO)
  • SNAP-LCE
  • SNAP-LCM4
  • M4
  • M4RTU
  • M4IO
This download is freeware. Before downloading, read the Legal Agreement.
Security Certificates
Current security certificates are embedded in the firmware for Opto 22 products. If you are using recent firmware or can update your device to current firmware, you do not need any of these certificates. If you cannot update firmware, then you can apply a certificate from this zip file as needed.
This zip file contains the following certificates:
  • DigiCert High Assurance EV Root CA (DigiCert.der) - Valid from 11/9/2006 to 11/9/2031
  • GeoTrust Primary Certification Authority (GeoTrustPCS.crt) - Valid from 11/26/2006 to 7/16/2036
  • GlobalSign Root CA (GSR1.crt) - Valid from 9/1/1998 to 1/28/2028
  • GTS Root R1 (gtsr1.der) - Valid from 6/21/2016 to 6/21/2036
  • GTS Root R2 (gtsr2.der) - Valid from 6/21/2016 to 6/21/2036
Certificate installation instructions are located here: Background information
A valid security certificate may be required by mail servers to allow you to send emails from your Opto 22 products, for example, through:
  • a PAC Control strategy running on a groov EPIC or SNAP PAC controller
  • a groov View HMI sending event notifications
  • a Node-RED flow on groov RIO or groov EPIC
Valid security certificates may also be required by other services you may be using via software on your Opto 22 device (for example, using Node-RED to move data in and out of Google Sheets).
All providers of email or other services update their security certificates from time to time. When that happens, your email or other service will stop working until you either install a new certificate or update firmware that contains the new certificate. Make sure you set up error handling procedures or other ways to verify that services are working.
Opto 22 updates certificates as soon as we know about new ones. If you see a security error (for example, -2104 in PAC Control) or have some other indication of a certificate issue, be sure to check for new firmware or download this zip file. If you need help, contact Opto 22 Product Support.
SNAP PAC RESTful API to Access Database Example
This download is an interactive Access database sample that builds commands to read data from an Opto 22 SNAP PAC programmable automation controller and store the data in a Microsoft Access table.
The download includes all files needed and a technical note documenting the sample. Before you download, read the Legal Agreement.
Watch the video below for an introduction to the samples.
SNAP PAC RESTful API to Excel Spreadsheet Example
This download contains sample spreadsheets you can use to read from and write to an Opto 22 SNAP PAC programmable automation controller via the PAC’s RESTful API. In this way you can securely share I/O point and variable data in your SNAP PAC controller with an Excel spreadsheet.
The download includes all files needed and a technical note documenting the samples. Before you download, read the Legal Agreement.
Video: SNAP PAC RESTful API to MS Excel
Click here to download the Excel example
What does the new built-in RESTful API in Opto 22 SNAP PAC S-series and R-series programmable automation controllers mean to you? It means you can use a variety of programming languages to easily access data in the PAC.
Data includes I/O point information plus variables in your PAC Control strategy. Using the REST API and HTTPS server in the PAC, you can securely share data with a wide variety of software applications, devices, and online services.
Video: SNAP PAC RESTful API to MS Access
Click here to download the Access example.
Video: SNAP PAC S Series Controllers
A quick overview of SNAP PAC S-series controllers.
Video: Controllers: SNAP-PAC-S1 vs. -S2
A quick overview of the differences between the SNAP-PAC-S1 and the SNAP-PAC-S2.
Video: Dual Ethernet Interfaces: Controllers vs. Brains
A quick overview of Dual Ethernet Interfaces: Controllers vs. Brains.
Video: Using SNAP PAC System with Ethernet/ IP
A quick overview of how any device using the EtherNet/IP protocol from Allen-Bradley can communicate with Opto 22 SNAP PAC controllers and brains. More info: IO4AB
Video: Webinar: Controller Redundancy in PAC Control 9
Learn how to implement controller redundancy in SNAP PAC systems.
SNAP PAC Networking
Learn the basics about dual ports, redundancy, segmenting, and daisy chaining of SNAP-PAC networking in this interactive demo.
What is a PAC?
Learn all about Programmable Automation Controllers (PACs) including the history of the term PAC, PAC features, and Opto 22 PACs.
