GRV-TERMG26-5
GRV-TERMG26-5
$145.00 (USA and Canada only)
groov I/O Module Terminal, Gray, for Thermocouple Modules, 5-pack
GRV-TERMG26-5 is a pack of five pluggable terminal connectors for field wiring. These connectors support cold-junction compensation for thermocouple channels and are used with the following groov I/O and groov RIO modules:
 If you have a GRV-IVAPM-3 or GRV-R7-I1VAPM-3, see GRV-TERMPM13-5. If you have a different groov I/O part number, see GRV-TERM26-5
Accepts wire sizes from 28–14 AWG.
Torque specification for connector screw: 2.5 in-lb (0.28 N-m)
groov Accessories Data Sheet
groov accessories are additional or replacement parts designed specifically for the groov EPIC system. This data sheet covers items like groov I/O terminal connectors and cables that save you time and money when wiring field devices to groov RIO and groov I/O modules.
