GRV-IVAPM-3
GRV-IVAPM-3
$895.00 (USA and Canada only)
Input, power monitoring, 3 phase, 600 V with 0.333 V, 1 V, or 5 A CT
GRV-IVAPM-3 analog input module provides an efficient way to monitor and measure power and energy usage in your facility. GRV-IVAPM-3 simultaneously measures volts AC RMS and amps AC RMS on Category III Wye (up to 400 VAC) or Delta (up to 600 VAC) circuits. It can monitor three-phase AC current using 0.333 V, 1 V, or 5 A current transformers (CT). Each phase can be configured to eliminate small signals from power measurement and energy accumulation to help you tune signal accuracy.
From the measured field inputs, the module automatically calculates additional channels of significant data, for a total of 64 data channels, including voltage and current; true, reactive and apparent power; power factor, frequency, net energy, and other values, as well as summations for all phases.
If the module is part of a groov EPIC system running a PAC Control™ strategy, strategy logic can automatically perform additional calculations and take action to address any issues detected.
Part of the groov EPIC system, mounts on a groov EPIC chassis together with a GRV-EPIC-PR1 or GRV-EPIC-PR2 processor and other analog, discrete, and serial groov I/O modules.
Features
Features GRV-IVAPM-3
Scaling x
Offset and Gain N/A
Minimum/Maximum Values x
Average Filter Weight x
Simple Moving Average N/A
Analog Totalizing x
Problem indication x
Specifications
Specification GRV-IVAPM-3
Maximum UL61010-3 Measurement Category Category III 600 VAC
Delta Voltage Input Ranges, Vrms 600, 520, 260 (Line-to-Line)
Wye Voltage Input Ranges, Vrms 400, 300, 150 (Line-to-Neutral)
Voltage Accuracy (% of range @ 50-60 Hz, excluding Voltage transformer) Wye: ±0.35%, Delta: ±0.5%
Current Transformer (CT) Outputs Supported 5.0 A, 1.0 VAC or 0.3333 VAC
Current Accuracy (% of CT range @ 50-60 Hz, excluding Current transformer) ±0.5%
Power Accuracy (% of (Vrms range) * (CT current rating), @ 50-60Hz) ±0.5%
Data Refresh Time 1 s
Step Response Time 1 s
Problem Indication Vrms out of range, Irms out of range
Isolation (field-to-logic) 3600 VAC working, 5400 VAC transient
Isolation (channel-to-channel) N/A
Number of Data Channels 64
Chassis Power Consumption 1.1 W
Minimum groov EPIC Firmware Version 3.3.0
Minimum PAC Project Version 10.4000
Minimum Library Package for CODESYS Version 2.0.3.0
Wire Size 28–14 AWG
Torque, connector screw 2.5 in-lb (0.28 N-m)
Torque, hold-down screw 3.5 in-lb (0.4 N-m)
Humidity (non-condensing) 5–95% RH
Agency Approvals UL/cUL(Class 1 Div. 2), CE, ATEX(Category 3, Zone 2), RoHS, DFARS; UKCA
Warranty Lifetime
groov Power Monitoring Module Data Sheet
The groov power monitoring module is part of Opto 22's groov EPIC System. This document includes descriptions, specifications, and wiring and dimensional diagrams for the GRV-IVAPM-3.
Press Release: Opto 22 releases new groov EPICĀ® I/O modules for large-scale power monitoring and signal integration
New modules announced are: GRV-IVAPM-3 for three-phase AC power monitoring, and GRV-MM1001-10 for universal I/O sensing and control.
GRV-IVAPM-3 Module Firmware
This download contains current firmware for the GRV-IVAPM-3 module. For a list of bug fixes and enhancements included in this firmware, see the groov I/O Modules Firmware Release Notes.
You can download the previous version of the firmware by clicking on this link: 1.3c1.3b
CAD Drawing: groov I/O Module
Accuracy vs Resolution
