GRV-TERMPM13-5
GRV-TERMPM13-5
$134.00 (USA and Canada only)
Terminal connector for groov power monitoring Modules, 5-pack
GRV-TERMPM13-5 is a pack of five pluggable terminal connectors for field wiring. These connectors support connections to high voltage loads and are used with the following groov I/O and groov RIO modules: If you have a groov I/O module or groov RIO module that supports thermocouple channels, see GRV-TERMG26-5.
If you have any other groov I/O part number, see GRV-TERMG26-5.
Accepts wire sizes from 28–14 AWG.
Torque specification for connector screw: 2.5 in-lb (0.28 N-m)
