$0.00 (USA and Canada only)
When added to a groov EPIC® processor (GRV-EPIC-PR1) or groov RIO* (GRV-R7-MM1001-10), this groov SHELL license lets you access the Linux® operating system through a secure shell (SSH). You'll be able to develop, download, and run control programs built with languages like Python, C/C++, and Java. *Requires groov RIO firmware 3.0 or higher.
TO OBTAIN AND INSTALL YOUR LICENSE:
You can find more detailed instructions in the groov EPIC User's Guide (form 2267) and the groov RIO User's Guide (form 2324).
This data sheet describes Opto 22's groov RIO® module, an edge I/O module for your remote Ethernet I/O for industrial internet of things (IIoT) and automation applications. With a single part number (GRV-R7-MM1001-10), you get built-in multifunction, multi-signal I/O; an I/O processor; power over Ethernet; and mounting without the need for a rack or chassis—in a compact industrial package. The module includes built-in processing and communication through web-based configuration, flow logic software, efficient data communication methods, centralized user management, and support for multiple operations technology (OT) and information technology (IT) protocols to simplify any IIoT or automation application.
This data sheet describes Opto 22's groov EPIC® processor, part number GRV-EPIC-PR1, an embedded Linux®, real-time controller with gateway functions. The processor is your central command to your groov EPIC system, which handles multiple control, automation, and data acquisition tasks involving digital and analog control, serial string handling, PID, and enterprise connectivity. The processor includes a high-resolution color touchscreen display. It provides USB and HDMI ports so you can extend its capabilities, as well as dual independent Gigabit Ethernet network interfaces. Software tools include groov Manage, groov View, PAC Project™, Node-RED, Ignition Edge® from Inductive Automation® , and CODESYS® Runtime Engine from CODESYS. Full use of some software tools requires a license; the following licenses are also covered in this data sheet:
This user's guide shows you how to assemble, initialize, configure, commission, and maintain a groov RIO, part number GRV-R7-MM1001-10. The guide explains:
This user's guide shows you how to assemble, initialize, configure, and maintain a groov EPIC system and use the groov EPIC processor, part number GRV-EPIC-PR1. The guide explains how to mount the power supplies, processor, and groov I/O modules onto the groov chassis, the first configuration steps to take after you turn it on, and how to keep the system up-to-date through system updates.
