The GRV-RIO-LC includes:
groov RIO® Learning Centers (part numbers GRV-RIO-LC and GRV-RIO2-LC) are fully functioning packages of Opto 22 hardware and software designed to help you learn how to use groov RIO Ethernet-based edge I/O. The companion groov RIO Learning Center Package can help jump start your learning by configuring your I/O to work with the load panel and the included Node-RED flows, which show you how to create a dashboard for browsers and mobile devices, work with a PID control loop, and write data to a file. These Learning Centers make it easy to get started with your automation and IIoT projects with a Proof of Concept, demonstration, or prototype.
This document describes how to install projects on your groov RIO Learning Center (part numbers GRV-RIO-LC and GRV-RIO2-LC). These projects are included in the groov RIO Learning Center Package.
This document comes in the box with your groov RIO Learning Center (part number GRV-RIO-LC and GRV-RIO2-LC). It shows you how to set up and use the Learning Center, including how to assemble and start it, install control programming software, and download completed project files to explore and compare to the ones you create.
This user's guide shows you how to assemble, initialize, configure, commission, and maintain a groov RIO universal I/O module, part numbers GRV-R7-MM1001-10 and GRV-R7-MM2001-10. It is also helpful for groov RIO Learning Centers (GRV-RIO-LC and GRV-RIO2-LC). The guide explains how to:
The groov RIO Learning Center Package contains a fully functional configuration file for the groov RIO Learning Center (part numbers GRV-RIO-LC and GRV-RIO2-LC), complete with configured I/O, Node-RED flows, a PID, and more. The configuration file demonstrates how to interact with the Learning Center's groov RIO I/O and load panel:
Part of the groov RIO Quick Start series, this video shows you how to work with I/O using a groov RIO Learning Center.
Using a groov RIO Learning Center, you'll get step-by-step instructions on how to set the time on a groov RIO I/O module.
Learn how to inspect a user account on a groov RIO I/O module using the groov RIO Learning Center.
Part of the groov RIO Quick Start series, this video shows you how to navigate network settings using a groov RIO Learning Center.
Learn the necessary steps to restore the Learning Center package to groov RIO.
$995.00
