$800.00 (USA and Canada only)
This data sheet describes Opto 22's groov EPIC® processor, part number GRV-EPIC-PR1, an embedded Linux®, real-time controller with gateway functions. The processor is your central command to your groov EPIC system, which handles multiple control, automation, and data acquisition tasks involving digital and analog control, serial string handling, PID, and enterprise connectivity. The processor includes a high-resolution color touchscreen display. It provides USB and HDMI ports so you can extend its capabilities, as well as dual independent Gigabit Ethernet network interfaces. Software tools include groov Manage, groov View, PAC Project™, Node-RED, Ignition Edge® from Inductive Automation® , and CODESYS® Runtime Engine from CODESYS. Full use of some software tools requires a license; the following licenses are also covered in this data sheet:
The groov Edge Appliance (groov Box) is Opto 22’s internet of things (IoT) and operator interface appliance that provides visualization, data handling, and connectivity to automation systems, software, databases, and devices of all kinds—all in a compact, industrially hardened box suited to the edge of the network.
Read about everything you can do with the groov Box and more in this data sheet, which covers the following part numbers:
This user's guide shows you how to assemble, initialize, configure, and maintain a groov EPIC system and use the groov EPIC processor, part number GRV-EPIC-PR1. The guide explains how to mount the power supplies, processor, and groov I/O modules onto the groov chassis, the first configuration steps to take after you turn it on, and how to keep the system up-to-date through system updates.
This user's guide shows you how to set up and configure a GROOV-AR1-BASE groov Box Edge Appliance and to work with the software in the Box, including:
$1,295.00
$1,495.00
