GRV-IACS-24
GRV-IACS-24
$300.00 (USA and Canada only)
AC discrete input, 24 channels, 85-140 VAC/VDC, on/off state only
Part of the groov EPIC® system, the GRV-IACS-24 AC digital input module provides input state from up to 24 devices such as pumps, fans, and motors that use a 85–140 VAC/VDC signal. Each of its 24 channels senses on or off status only. The module cover includes an LED that indicates status and a touch-sensitive pad. Touch the pad and the groov EPIC processor displays information about the module, including specifications and a wiring diagram.
The GRV-IACS-24 module mounts on a groov EPIC® chassis with other groov I/O modules (discrete, analog, and serial) and a GRV-EPIC-PR1 or GRV-EPIC-PR2 processor.
NOTE: If your application requires additional features like latching and totalization, see the GRV-IAC-24.
Feature GRV-IAC-24 GRV-IACS-24 GRV-IACI-12 GRV-IACIS-12
Number of Channels 24 24 12 12
Channel-to-Channel Isolation
Counting
Frequency Measurement
On/Off Latching
On/Off State
On/Off Totalization
Period Measurement
Pulse Measurement
Quality Indication
Specification GRV-IAC-24 GRV-IACS-24 GRV-IACI-12 GRV-IACIS-12
Nominal Input Voltage Range (RMS) 85–140 VAC / VDC 85–140 VAC / VDC 85–140 VAC / VDC 85–140 VAC / VDC
Turn-on Voltage 85 VAC / VDC 85 VAC / VDC 85 VAC / VDC 85 VAC / VDC
Turn-off Voltage 35 VAC / VDC 35 VAC / VDC 35 VAC / VDC 35 VAC / VDC
Input Impedance (± 5%) 133 kOhms 133 kOhms 68 kOhms 68 kOhms
Operating Frequency 40 Hz to 400 Hz or DC 40 Hz to 400 Hz or DC 40 Hz to 400 Hz or DC 40 Hz to 400 Hz or DC
Isolation (channel-to-channel) None None 300 V working 300 V working
Chassis Power Consumption 1.0 W 1.0 W 1.0 W 1.0 W
Agency Approvals UL/cUL (Class 1 Div. 2)a; CE: ATEX (Category 3, Zone 2) and RoHS; DFARS; CB Scheme; UKCA
groov 115 VAC/VDC Input Modules Data Sheet
groov 115 VAC/VDC input modules are part of Opto 22's groov EPIC® System. They can handle input ranges from 85 VAC/VDC to 140 VAC/VDC.
This document includes descriptions, specifications, and wiring and dimensional diagrams for the following part numbers:
groov simple I/O modules firmware
  • GRV-IACHVS-24
  • GRV-IACIHVS-12
  • GRV-IACS-24
  • GRV-IACIS-12
  • GRV-IDCS-24
  • GRV-IDCIS-12
  • GRV-OACS-12
  • GRV-OACIS-12
  • GRV-IACDCTTLS-24
  • GRV-ODCIS-12
  • GRV-OMRIS-8
You can download previous versions of the firmware by clicking on the following links: 1.6e, 1.4b
GRV-IACS-24 Module Firmware
This download contains current firmware for the GRV-IACS-24 module. For a list of bug fixes and enhancements included in this firmware, see the groov I/O Modules Firmware Release Notes.
You can download the previous version of the firmware by clicking on this link: 1.6e1.4b
CAD Drawing: groov I/O Module
