GRV-ODCSRC-24
GRV-ODCSRC-24
$525.00 (USA and Canada only)
groov 24-channel discrete DC output module, sourcing
The GRV-ODCSRC-24 is part of the groov EPIC® system. This digital DC output module has 24 channels, each of which can switch loads of 5-60 VDC. This module is load sourcing. (If you're unsure whether you need a sourcing module, see the sinking/sourcing demo.)
The GRV-ODCSRC-24 mounts on a groov EPIC chassis with a GRV-EPIC-PR1 processor and additional discrete, analog, and serial groov I/O modules, providing the mix of signals you need.
Feature GRV-ODCSRC-24
Channel-to-channel isolation
On/off state x
Output Pulsing/TPO x
On/off totalization x
Problem indication
Watchdog Timeout Value x
Specification GRV-ODCSRC-24
Line Voltage Range (nominal) 12–24 VDC
Line Voltage Range (max) 5–60 VDC
Current Rating (per channel) 0.4 A
Surge Current 1.5 A for 1.0 Second
Recommended Max. Fuse (fast) / Circuit Breaker 2 A, 60 VDC / channel or 20 A, 60 VDC common
Minimum Load 5.0 mA
Output Voltage Drop 0.3 V max. at 0.4 A
Off-State Leakage (per channel) <10 µA (@ 60 V, 70 °C)
Peak Blocking Voltage 60 V DC
TPO Period (min, max, resolution) 0.005 seconds, 429496.7296 seconds, 0.001 seconds
Turn On / Off Time 2.5 ms
Isolation (field-to-logic) 300 V working, 1500 V transient
Isolation (channel-to-channel) None
Number of Channels 24
Chassis Power Consumption 1.2 W
Minimum GRV-EPIC-PR1 Firmware Version 1.0.0
Minimum PAC Project Version 10.0000
Minimum Library Package for CODESYS Version 1.0.0.0
Wire Size 28–14 AWG
Torque, connector screw 2.5 in-lb (0.28 N-m)
Torque, hold-down screw 3.5 in-lb (0.4 N-m)
Relative Humidity (non-condensing) 5–95%
Agency Approvals UL/cUL (Class 1 Div. 2)a; CE, ATEX( Category 3, Zone 2), RoHS; DFARS; CB Scheme; UKCA
Warranty Lifetime
groov DC Output Sourcing Module Data Sheet
The groov® DC output sourcing module, part number GRV-ODCSRC-24, is part of Opto 22's groov EPIC® System. This document includes descriptions, specifications, and wiring and dimensional diagrams for the DC output sourcing module.
GRV-ODCSRC-24 Module Firmware
This download contains current firmware for the GRV-ODCSRC-24 module. For a list of bug fixes and enhancements included in this firmware, see the groov I/O Modules Firmware Release Notes.
You can download previous versions of the firmware by clicking on these links:  1.3d1.3c1.3b1.3a1.0n
CAD Drawing: groov I/O Module
