Specification
GRV-ITR-12
Input Ranges (Ohms)
400 K, 200 K, 100 K, 50 K, 40 K, 20 K, 10 K, 5 K, 4 K, 2 K, 1 K, 500 Ohms, and Autorange
Accuracy (Ohms @ Range)
400@400 K, 200@200 K, 100@100 K, 50@50 K, 40@40 K, 20@20 K, 10@10 K, 5@5 K, 4@4 K, 2@2 K, 1@1 K, 0.5@500 Ohms
Excitation Current
(Range & Load Watts Dissipated)
>7.9 µA (400 K & 25 µW), (200 K & 12.4 µW), (100 K & 6.2 µW), (50 K & 3.1 µW),
>84.7 µA (40 K & 287 µW), (20 K & 144 µW), (10 K & 72 µW), (5 K & 36 µW),
>169.2 µA (4 K & 115 µW), (2 K & 57 µW), (1 K & 29 µW), (500 & 14 µW)
Data Refresh Rate
950 ms
Analog Data Filtering
-3 dB @ 2.4 Hz / -25 dB @ 60 Hz
Software Data Filtering
- Simple Moving Average (SMA)
- Weighted Average
- SMA (1 to 32 readings)
- Weighted Average (1 to 4096)
Step Response Time (to 1%)
85 ms
Problem Indication
out of range
Isolation (field-to-logic)
300 V working, 1500 V transient (1 minute)
300 V between channel group 0–5 & channel group 6–11. None within a group.
Number of Channels
12
Chassis Power Consumption
1.3 W
Minimum GRV-EPIC-PR1 Firmware Version
1.3.0
Minimum PAC Project Version
10.2000
Minimum Library Package for CODESYS Version
1.0.0.0
Wire Size
28–14 AWG
Torque, connector screw
2.5 in-lb (0.28 N-m)
Torque, hold-down screw
3.5 in-lb (0.4 N-m)
Temperature (operating)
-20 °C to +70 °C
Temperature (storage)
-40 °C to +85 °C
Humidity (non-condensing)
5–95% RH
UL/cUL (Class 1 Div. 2)a, CE, ATEX (Category 3, Zone 2), RoHS, DFARS
Lifetime
a For use in hazardous locations, equipment must be mounted in an enclosure that meets the requirements of the National Electrical Code, ANSI/NFPA 70, and ANSI/ISA-61010-1 (82.02.01).
