KB90718
Published: September 19, 2023
PAC Display Runtime may crash when ODBC database unavailable
PAC Display Runtime Professional
R9.4a to current
PAC Display Runtime Professional may crash if there is a network error when attempting to connect to or communicate with an ODBC database.
Address any network errors with the ODBC connector at the source (server, firewall, etc.), and ensure there is a stable connection to your database.
If your project references an unused ODBC connector, set the ODBC Data Source option to None in PAC Display Configurator to avoid potential issues. For instructions, refer to the PAC Display User's Guide (1702).
