$100.00 (USA and Canada only)
This data sheet describes Opto 22's groov RIO® Energy Monitoring Unit (EMU), an edge energy monitoring module for industrial internet of things (IIoT) and automation applications. With a single part number (GRV-R7-I1VAPM-3), you can monitor AC voltage, current, power, and energy usage on wye or delta circuits up to UL 61010-3 measurement category III; power over Ethernet; and mounting without the need for a rack or chassis—in a compact industrial package. It can monitor three-phase AC current using 0.333 V, 1 V, or 5 A current transformers (CT). The module includes built-in processing and communication through web-based configuration, flow logic software, efficient data communication methods, centralized user management, and support for multiple operations technology (OT) and information technology (IT) protocols to simplify any IIoT or automation application.
This data sheet describes Opto 22's groov RIO® Universal I/O modules: Ethernet-based edge I/O for industrial internet of things (IIoT) and automation applications. With a single part number, you get 8 software-configurable analog or discrete inputs or outputs plus 2 electromechanical relays, power over Ethernet, data processing and communications, and more, all in a compact industrial package. The data sheet covers these RIO Universal I/O part numbers:
This download contains the Opto 22 Library Package for CODESYS Development System. Install this package to your CODESYS Development System so you can begin adding groov EPIC and groov RIO devices to your CODESYS project. For information on enhancements, features, or bug fixes in each release, see the Release Notes for Library Package for CODESYS. For instructions on how to install the package, see:
