| Description |
Edge programmable industrial controller |
Universal edge I/O |
Universal edge I/O with Ignition Edge |
Energy monitoring edge I/O |
Server for groov View HMI |
| Industrially hardened device |
(Depends on PC) |
| Software that runs on Windows PC |
| Field I/O |
0-16 groov I/O modules can be placed on same chassis |
Built-in, software configurable I/O |
64 energy data channels |
| Purpose |
| Real-time industrial control |
| I/O |
| Data processing |
| Data communication |
| IIoT connectivity |
| Visualization (HMI) |
| Software |
| Control programming |
- PAC Control software
- CODESYS® Development System (all IEC 61131-3 compliant languages)
- Custom programs run via secure shell access (SSH) |
CODESYS® Development System (all IEC 61131-3 compliant languages) |
| Node-RED (data flows, dashboard) |
| MQTT communications (string and Sparkplug) |
| Ignition from Inductive Automation® (additional cost) |
Ignition 7*** (or 8**) |
Ignition 8 |
Ignition 8 |
| Ignition Edge® (additional cost; OPC UA drivers for PLCs, Modbus®/TCP devices & software; MQTT/Sparkplug communications) |
Ignition Edge 7*** (or 8**) |
Ignition Edge 8 |
Ignition Edge 8 |
| groov View (HMIs for mobile devices, PCs, any device with a web browser) |
| groov Manage (configuration) |
| Secure shell access (SSH) |
| IIoT Connectivity |
| OPC UA (multiple independent servers) |
| - Native to I/O & OptoMMP Scratch Pad |
| - Native to PAC Control variables & I/O |
| - Ignition tags, including 3rd-party drivers |
| - CODESYS program & I/O |
| - Node-RED via OPC UA Server node |
| MQTT with strings and Sparkplug B |
| Node-RED |
| RESTful APIs |
- PAC Control variables
- groov Manage (to I/O)
- groov View Data Stores |
groov Manage (to I/O) |
| Data Handling |
| Data acquisition |
| Data storage |
| Data processing |
via Node-RED |
via Node-RED |
via Node-RED |
| Security and Networking |
| Data encryption (HTTPS/TLS) |
| User authentication |
| Self-signed or Certificate Authority certificates |
| Device firewall, configurable |
| LDAP support |
| SNMP support (V1, V2, and V3) |
| VPN client |
(Depends on IT) |
| Two independent Ethernet NICs (different IP addresses) |
(Depends on PC) |
| Two switched Ethernet NICs (same IP address) |
| HDMI ports |
One (for external monitor) |
| USB ports |
Two USB 2.0 (for external keyboard or mouse, WiFi adapter, serial adapter, approved USB Bluetooth adapter, or USB memory stick to 32 GB) |
One USB 2.0 (for WiFi adapter, serial adapter, or USB memory stick to 32 GB) |
| General |
| Built-in, high-resolution color touchscreen display |
| Mounting |
Requires groov EPIC chassis. Chassis is DIN-rail or panel mounted. |
Self-contained; DIN-rail or panel mounted |
| Power |
AC, DC, or pass-through power supply options on chassis |
Power over Ethernet or 10–32 VDC input |
| Operating temperature |
-20 °C to +70 °C |
-20 °C to +70 °C |
(Depends on PC) |
| Storage temperature |
-40 °C to +85 °C |
-40 °C to +85 °C |
| Relative humidity, non-condensing (operating) |
5 to 95% |
5 to 95% |
(Depends on PC) |
| Agency approvals |
UL/cUL (Class 1 Div. 2); CE, ATEX (Category 3, Zone 2), UKCA,RoHS; DFARS; CB Scheme |
UL/cUL (Class 1 Div. 2); CE, ATEX (Category 3, Zone 2), UKCA, RoHS; DFARS; CB Scheme |
| Warranty |
Processor: 30 months. Most I/O modules: lifetime warranty. |
30 months |
*Via the Node-RED dashboard UI (both Node-RED Dashboard versions, 1.0 and 2.0 (FlowFuse Dashboard), are supported as of groov EPIC and RIO firmware version 4.1.0).
**GRV-EPIC-PR2 is recommended for Ignition version 8, due to its larger memory.
***Ignition 7 is only for existing license holders; these licenses are no longer available for purchase. To use Ignition 7, you must run firmware version 4.0.3 or lower. |
