KB90853
Published: February 5, 2024
PAC Manager may not accept 12-digit IP address and subnet mask for ETHERNET 2 Interface
R9.6 to current
On the Status Write page of the Inspect window of PAC Manager, you may not be able to enter an IP address or subnet mask that contains 12 digits (3 digits in all 4 octets, such as 255.255.255.255) for the ETHERNET 2 Interface.
Make the Inspect window wider:
- Open the Inspect window in PAC Manager (Tools > Inspect and click Status Write).
- Place the mouse on the right edge of the window until it changes to a resize arrow.
- Drag the window edge out to the desired size.
- Close and reopen the window to enter the IP address or subnet mask into the larger window.
