KB90852
Published: February 28, 2024
Using OptoDataLink with Microsoft SQL Server 2022 may result in an error
OptoDataLink
R1.0 to current
When using OptoDataLink with Microsoft SQL Server 2022, you may encounter an error that the SQL Server Native Client 11.0 is not installed.
Install SQL Server Native Client 11.0 on the computer. Review this Microsoft article for instructions.
NOTE: If your computer has a 64-bit operating system, ensure you install the 64-bit version of SQL Server Native Client 11.0.
