KB90762
Published: December 6, 2023
groov discrete input counters may momentarily report a value 256 less than actual
Firmware for the following groov I/O modules:
  • GRV-IAC-24
  • GRV-IACDCTTL-24
  • GRV-IACHV-24
  • GRV-IDC-24
  • GRV-IACI-12
  • GRV-IACIHV-12
  • GRV-IDCI-12
  • GRV-IDCSW-12
  • GRV-IDCIFQ-12
For the following modules, all versions lower than R1.3d:
  • GRV-IAC-24
  • GRV-IACDCTTL-24
  • GRV-IACHV-24
  • GRV-IDC-24
  • GRV-IACI-12
  • GRV-IACIHV-12
  • GRV-IDCI-12
  • GRV-IDCSW-12
For the following modules, versions lower than R1.3e:
  • GRV-IDCIFQ-12
For the following modules, R1.3d:
  • GRV-IAC-24
  • GRV-IACDCTTL-24
  • GRV-IACHV-24
  • GRV-IDC-24
  • GRV-IACI-12
  • GRV-IACIHV-12
  • GRV-IDCI-12
  • GRV-IDCSW-12
For the following modules, R1.3e:
  • GRV-IDCIFQ-12
For the affected modules, while observing or recording measurements from a channel configured with the counter feature, there may be a scan (or, at most, two) that reports a value 256 less than the expected value. This issue may occur every 256 counts, so higher frequencies yield errors more frequently.
In your programming, filter out decreasing counter values.
