KB90749
Published: October 17, 2023
Transparent blinking graphic objects may crash PAC Display Runtime
All versions
If you run a project that contains graphic objects configured for both transparency and blinking, PAC Display Runtime may eventually crash.
To minimize crashing, avoid configuring graphic objects with both transparency and blinking properties where possible.
