KB90736
Published: September 29, 2023
Digital output ON/OFF totalization unsupported in PAC Display Configurator
PAC Display Configurator Basic
PAC Display Configurator Professional
R10.5a to current
If you have a tag with a digital (discrete) output configured as an ON or OFF time totalizer in your PAC Control strategy, you may encounter the error message: “Unable to Load Digital Point Objects.” when that tag and others fail to load properly in PAC Display Configurator.
Additionally, when configuring your tags in the Value Tag Selection window in PAC Display Configurator, you may notice some I/O tags from your PAC Control strategy are missing.
