KB90559
Published: September 15, 2023
Control items in PAC Display do not fit in dialog windows
All versions
When using PAC Display Configurator, you may notice inconsistent fonts and configuration fields that do not fit in dialog windows as illustrated in the following example (inconsistent fonts are within the red box and fields that do not fit are highlighted):
Ask your IT group to modify the registry on your computer to include the “Microsoft Sans Serif” font as a substitute for the “Helv” font. If you don't have an IT group, carefully follow these instructions:
- Use regedit.exe and navigate to: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\FontSubstitutes
- Modify the “Helv” Windows registry item to replace the legacy “MS Sans Serif” font with the current “Microsoft Sans Serif” font.
- Restart your computer for the changes to take effect.
