KB90549
Published: March 30, 2023
groov discrete modules occasionally report unusually large frequency measurements
Firmware for the following modules:
  • GRV-IAC-24
  • GRV-IACI-12
  • GRV-IACIHV-12
  • GRV-IACDCTTL-24
  • GRV-IACHV-24
  • GRV-IDC-24
  • GRV-IDCI-12
  • GRV-IDCIFQ-12
  • GRV-IDCSW-12
  • For the following modules,  R1.3a to current:
    • GRV-IACI-12
    • GRV-IACIHV-12
    • GRV-IACDCTTL-24
    • GRV-IACHV-24
    • GRV-IDCI-12
  • For the following modules, R1.3a to R1.3b:
    • GRV-IAC-24:  R1.3c
    • GRV-IDC-24:  R1.3c
    • GRV-IDCIFQ-12:  R1.3c
    • GRV-IDCSW-12:  R1.3c
  • GRV-IAC-24:  R1.3c
  • GRV-IDC-24:  R1.3c
This issue occurs on channels configured with the continuous frequency feature. Occasionally, the module reports an unusually large value that persists for one measurement scan, typically no more than one second. The rate of occurrence of this issue depends on the input frequency of the field device, but it does not occur often. The higher the input frequency, the more often the module may report a very large frequency measurement.
Ignore the very large frequency value and use the next frequency measurement.
