KB90529
Published: May 23, 2023
"Averaging Filter Weight" checkbox not checked when upgrading strategy that has "Set Value" checked
PAC Control Professional
All versions prior to R10.5b
R10.5b
If you have a pre-R10.5a strategy that contains analog inputs where the Send Value checkbox is checked and a value is specified for Average Filter Weight, when you open that strategy in PAC Control R10.5a, the Averaging Filter Weight check box is not checked, though the value is preserved.
Note: In R10.5a, the Add/Edit Analog Point window was changed:
- The Send Value checkbox was replaced with an Averaging Filter Weight checkbox.
- The Send Values checkbox was replaced with an Offset checkbox.
