KB90518
Published: August 17, 2023
Deploying a large Node-RED project causes a 413 error
- GRV-EPIC-PR1
- GRV-EPIC-PR2
groov RIOs:
- GRV-R7-MM1001-10
- GRV-R7-MM2001-10
- GRV-R7-I1VAPM-3
groov EPICs: All versions prior to 3.5.0
groov RIOs: All versions prior to 3.5.0
For groov EPICs and groov RIOs: 3.5.0
When you deploy a large Node-RED project, the deployment fails and the Node-RED editor displays "Deploy failed: 413 Request Entity Too Large" error message.
Contact Opto 22 Product Support for help with a workaround.
