KB90325
Published: November 18, 2022
Autorun flag toggled when groov Manage & PAC Control are both open
- PAC Control Professional
- PAC Control Basic
R10.4 to R10.4c
R10.5a
If you are switching between groov Manage and PAC Control using the icons in the Windows taskbar, while the Inspecting Control Engine dialog is open, the autorun flag might be toggled. The issue is more likely to occur with the following conditions:
- PAC Control is open with a strategy loaded in Debug mode and the strategy is stored in permanent storage (flash).
- groov Manage is open to the PAC Controller page.
Click on the PAC Control window instead of the icon on the task bar to gain the window's focus.
