KB90239
Published: August 24, 2022
Frequently writing unchanged values to some OptoMMP areas may cause excessive writes to permanent storage
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
  • GRV-R7-MM1001-10
  • GRV-R7-MM2001-10
  • GRV-R7-I1VAPM-3
For groov EPICs: 3.0.0 to 3.4.1
For groov RIOs: 3.0.0 to 3.4.0
For groov EPICs: 3.4.2
For groov RIOs: 3.4.1
The following areas of the OptoMMP memory map trigger writes to permanent storage:
  • (EXPANDED) Analog & Digital Channel Configuration
  • Streaming Configuration
  • Custom Configuration
  • Modbus Configuration
  • PAC Control Engine Configuration
  • Public Tags configuration
  • PID Configuration and Status
Frequently writing unchanged values to these areas causes excessive writes, which shortens the life of the permanent storage.
Add logic to your PAC Control strategy, CODESYS application, or custom program to write to these areas only if a value changes.
