KB90225
Published: April 14, 2022
CODESYS PROFINET Fieldbus Stops Working After 12.5 Days
CODESYS Development System (IDE) when used with:
- GRV-EPIC-PR1
- GRV-EPIC-PR2
This issue affects CODESYS Development System (IDE), which is used for writing CODESYS programs. Any versions that contain PROFINET versions 4.1.0.0, 4.2.0.0, 4.2.1.0 will have this issue.
CODESYS PROFINET version 4.2.2.0
NOTE: This KB article is for informational purposes. This issue is not a defect in GRV-EPIC-PR1 nor GRV-EPIC-PR2.
The CODESYS PROFINET fieldbus stops after about 12.5 days (or a multiple of that, depending on the bus cycle period).
Do the following:
- In the CODESYS Development System, use the CODESYS Installer (Tools > CODESYS Installer) to install PROFINET version 4.2.2.0 or higher.
- Re-build and re-download the application to the CODESYS control engine on the GRV-EPIC-PR1 or GRV-EPIC-PR2.
