KB90221
Published: July 7, 2022
Static Route remains in effect after deletion
- GRV-EPIC-PR1
- GRV-EPIC-PR2
groov RIOs:
- GRV-R7-MM1001-10
- GRV-R7-MM2001-10
- GRV-R7-I1VAPM-3
For groov EPICs: 3.0.0 to 3.3.3
For groov RIOs: 3.0.0 to 3.3.1
For groov EPICs: 3.4.0
For groov RIOs: 3.4.0
After deleting a static route, groov Manage removes it from the list of static routes on the Static Routes page, but it continues to exist in the IP routing table, which means it remains in effect.
Do either of the following:
- Cycle power to the groov EPIC processor or groov RIO module.
- On the network interface assigned the deleted static route(s), disconnect then reconnect the Ethernet cable.
