KB90193
Published: June 17, 2022
When copying and pasting groups of gadgets, z-order is not preserved
Firmware for the following groov EPIC processors:
- GRV-EPIC-PR1
- GRV-EPIC-PR2
groov View on the following:
- GROOV-AT1, GROOV-AT1-SNAP
For groov EPIC processors: All versions prior to 3.4.0
For all other part numbers: All versions prior to 4.4a
For groov EPIC processors: 3.4.0
For all other part numbers: 4.4a
When a group of gadgets is copied and pasted, the relative z-order of gadgets (the order in which gadgets are in front of or behind each other) is not preserved. Instead, the gadgets are pasted in the order they were selected.
