KB90181
Published: June 17, 2022
FTP "dir" command may not return all of the directory entries from an FTP server
Firmware for the following:
- GRV-EPIC-PR1
- GRV-EPIC-PR2
All versions prior to 3.4.0
3.4.0
In a PAC Control strategy, if you use the Set Communication Handle FTP dir command to obtain the directory listing of a directory with many files, the dir command may return only a partial directory listing.
If possible, limit the number of files in directories on the remote FTP server.
