KB90090
Published: April 5, 2022
Control engine sometimes overwrites filter, offset, and gain values on analog inputs
- GRV-EPIC-PR1
- GRV-EPIC-PR2
All versions
With this issue, the control engine may set the filter, offset, or gain value for an analog input channel to zero, even if the "Send" box is not checked.
Do one of the following in PAC Control:
- In the channel configuration dialog, set the values you want and check the "Send" box.
- In Block 0 of the Powerup chart, add commands that set the desired values.
