KB90069
Published: December 7, 2021
Erratic GRV-IDCIFQ-12 frequency readings
Firmware for GRV-IDCIFQ-12
1.3b
1.3c
This issue occurs on channels configured with the continuous frequency feature. When the input frequency is above approximately 500 Hz, the readings jump up and down around the nominal input frequency by more than ±2%.
Use version R1.3a of the module firmware.
