KB90031
Published: October 29, 2021
Get & Clear Analog Minimum / Maximum / Totalizer commands return a "Not Implemented" error
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
3.3.0 to current
In a PAC Control strategy, if you use any of the following commands on a groov analog input, you will see a "Not Implemented" error in the message queue:
  • Get & Clear Analog Maximum Value
  • Get & Clear Analog Minimum Value
  • Get & Clear Analog Totalizer Value
