KB90022
Published: November 1, 2021
After editing a computed tag's script, output doesn't change
groov View running on the following:
  • GRV-EPIC-PR1, GRV-EPIC-PR2
  • GROOV-AT1, GROOV-AT1-SNAP
  • GRV-EPIC-PR1, GRV-EPIC-PR2: 3.2.2 to 3.3.0
  • All other products: R4.3d to R4.3e
  • GRV-EPIC-PR1, GRV-EPIC-PR2: 3.3.1
  • All other products: R4.3f
If you edit a computed tag and change the tag's script, but not its inputs, you will not see the computed tag's output value change immediately. It won't change until one of the tag's input values changes.
If you can, force one of the input values to change; then, you can view the change in the computed tag's output.
