KB89802
Published: June 23, 2021
GRV-ITM-12 module disconnects and reconnects at random times.
Firmware for GRV-ITM-12
R1.3d
R1.3e
You may observe either of the following behaviors:
  • Upon powerup of the chassis, some GRV-ITM-12 modules on the chassis may not get discovered or discovery is delayed.
  • After power-up and initial module discovery, some GRV-ITM-12 modules may drop off-line and be rediscovered at random intervals, which is indicated by the module LED toggling between red and blue.
