KB89648
Published: April 29, 2021
When I/O unit reconnects after timeout, digital input latches and counters may be incorrect
Library Package for CODESYS Development System
2.0.0.0 to 2.0.1.1
2.0.2.0
In a CODESYS application with a GRV-R7-MM1001-10 or GRV-EPIC-PR1 that has digital I/O configured with latches or counters, if the I/O unit reconnects after a timeout, the latches and counters current values may be incorrect. After the values are cleared, they work correctly.
