KB89636
Published: June 15, 2021
Modbus/TCP transactions may fail
- GRV-EPIC-PR1
- GRV-EPIC-PR2
groov RIOs:
- GRV-R7-MM1001-10
- GRV-R7-MM2001-10
For listed groov EPICs: All versions prior to 3.2.1For listed groov RIOs: All versions
For listed groov EPICs: 3.2.1
When using a Modbus/TCP client to access the Modbus/TCP server on groov EPIC and groov RIO units, some transactions may fail even when accessing valid Modbus/TCP registers or a valid memory map region.
