KB89624
Published: April 16, 2021
Chart May Freeze When Strategy Uses a Command That Starts an SSL Client Session
Firmware for GRV-EPIC-PR1
3.0.0 to 3.1.0
3.2.0
When using a command that starts an SSL client session, such as HTTP Get or Send Email (with SSL enabled), the chart may freeze. Once this occurs, other charts using these commands will also freeze, and if you try to stop the strategy, the Host port will become unresponsive.
