KB89593
Published: March 11, 2021
Changes to Inputs Received Slower Than Configured Streaming Interval
Library Package for CODESYS Development System
2.0.1.0 (may affect earlier versions)
2.0.1.1
In a CODESYS application, input values from I/O will not be as fresh as the configured Streaming Internal. When you are monitoring the values of discrete or analog inputs (for example, through the debugger), you may see delays before the values change.
