KB89381
Published: February 11, 2021
Control Engine May Reset When Inspecting Variables and Stepping Through Subroutines
Firmware for:
  • GRV-EPIC-PR1
  • SNAP-PAC-S2, SNAP-PAC-S2-W
  • SoftPAC
GRV-EPIC-PR1 firmware: All versions prior to 3.1.0
PAC firmware: All versions prior to R10.4c
GRV-EPIC-PR1 firmware: 3.1.0
PAC firmware: R10.4c
While debugging a PAC Control strategy under the following conditions, the PAC control engine may reset:
  • You are stepping out of a subroutine that contains a local variable with the same name and type as a global variable in the calling strategy.
  • You are inspecting that local variable while stepping out of its subroutine into another subroutine.
  • You are stepping into another subroutine that does not contain a local variable with the same name and type as the local variable you are inspecting.
Do not inspect a subroutine local variable when stepping out of the subroutine if the variable has the same name and type as a global variable in the calling strategy.
