KB89327
Published: December 23, 2020
Values for Quality May Be Incorrect or Inconsistent in Inspect Windows
- PACCONTROLBAS (PAC Control Basic)
- PACCONTROLPRO (PAC Control Professional)
R10.3c
R10.3d
In PAC Control, you may observe either of the following for analog or digital channels on a groov RIO:
- When you are inspecting an analog channel in both the I/O unit's inspection window and the channel's inspection window, if you change the XVAL to a value that produces a bad quality indicator, the I/O unit's inspection window shows Bad for Quality, but the channel's inspection window shows Good for Quality.
- If the value of an analog channel changes to produce a bad quality indicator, the inspection windows may not change the Quality field/column from Good to Bad.
