KB89268
Published: December 23, 2020
Quality Indicator Disabled for All Channels Transferred Through an OTG File
  • PACCONTROLBAS (PAC Control Basic)
  • PACCONTROLPRO (PAC Control Professional)
R10.3a to R10.3c
R10.3d
In PAC Control, when you export groov EPIC or groov RIO I/O units from one strategy to an Opto Tag Database (OTG) file, then import the OTG file into another strategy, all channels in the second strategy will be configured with the quality indicator disabled. Any channels configured with the quality indicator enabled in the original strategy will not have their indicator enabled in the second strategy.
After importing the I/O units from the OTG file, in PAC Control config mode, manually enable the quality indicator for the groov EPIC and RIO channels to match the original I/O configuration.
