KB89233
Published: September 8, 2020
groov View does not display change in data type of a Data Store tag
groov View running on:
- GROOV-AT1, GROOV-AT1-SNAP
- GRV-EPIC-PR1
4.2a to current
In Build mode, if you edit the type of a tag in a Data Store, groov View doesn't reflect that change until you leave and re-enter Build mode or refresh the browser:
- In the Configure Devices and Tags window, select the Data Store
- Click Configure Tags.
- Double-click on a tag name.
- Change the data type
- Click Save, then Close.
Click Configure Devices and Tags window, select the Data Store, then click Configure Tags. You'll see that the tag's data type looks unchanged.
After you change the data type, refresh the browser or leave Build mode and then re-enter it. groov View will then show the correct tag type.
