KB89181
Published: December 8, 2020
Node-RED Behaves Oddly After User Logs Out
Firmware for:
- GRV-EPIC-PR1
- GRV-R7-MM1001-10
GRV-EPIC-PR1: All versions prior to 3.0.0GRV-R7-MM1001-10: All versions prior to 3.0.0
GRV-EPIC-PR1: 3.0.0GRV-R7-MM1001-10: 3.0.0
If you are logged into groov Manage in one browser tab and you have the Node-RED Editor loaded into another tab of the same browser, when you are logged out of groov Manage (either by you signing out or by some other process), you may observe any of the following:
- The Editor appears to continue working, though you may observe odd behavior.
- The Deploy button and Inject nodes appear to continue working; however, you may observe odd behavior.
Log back into your groov EPIC.
