KB89099
Published: September 18, 2020
Writes to Digital Packed Data Area of memory map fail; discrete output not modified
Firmware for:
  • GRV-EPIC-PR1
  • GRV-R7-MM1001-10
For GRV-EPIC-PR1: All versions prior to 2.0.2
For GRV-R7-MM1001-10: 2.0.0 to 2.0.1
For GRV-EPIC-PR1: 2.0.2
For GRV-R7-MM1001-10: 2.0.2
If you write to the Digital Packed Data Area of the memory map (0xF1001800–0xF100183F), the writes fail and the discrete output states are not modified.
Write to these other areas of the memory map:
  • Digital Channel, 0xF0220000
  • Digital Packed Data, 0xF1001900
  • Digital Packed Must On/Off, 0xF1001A00
