KB89056
Published: July 22, 2020
Enable Communication to I/O Unit Command Does Not Enable EPIC I/O Unit
Firmware for GRV-EPIC-PR1
2.0.0 to 2.0.1
2.0.2
If an error causes a groov EPIC I/O unit to go offline, the Enable Communication to I/O Unit command may not re-enable it, even if the error condition has been cleared.
You can bring the I/O unit back online with either of these methods:
  • Enable the I/O unit with the PAC Control Debug I/O Unit Inspect dialog, or
  • Stop and re-start the strategy.
