KB89048
Published: July 22, 2020
Node-RED Stops Responding or Behaves Irregularly
Firmware for:
  • GRV-EPIC-PR1
  • GRV-R7-MM1001-10
For GRV-EPIC-PR1 Firmware: All versions prior to 2.0.1
For GRV-R7-MM1001-10 Firmware: All versions
GRV-EPIC-PR1: 2.0.2
After being signed into a groov EPIC (GRV-EPIC-PR1) or groov RIO (GRV-R7-MM1001-10) for two weeks or so, you may notice that Node-RED stops responding correctly or behaves strangely. For example, the deploy button appears to deploy the flow, but the timestamps are incorrect. If you try to refresh the page (to try to fix the behavior), you are logged out.
Log back into the groov EPIC (GRV-EPIC-PR1) or groov RIO (GRV-R7-MM1001-10).
