KB89009
Published: May 20, 2020
PAC Control: Can't enable communication to I/O unit that has missing or incorrect groov module
Firmware for GRV-EPIC-PR1
2.0.0
2.0.1
If a PAC Control strategy contains a channel on a GRV-EPIC-PR1 I/O unit, and the module that contains that channel is missing or not the right one, communication to the I/O unit does not enable.
Mount the missing or correct module, then run your strategy.
